How do I copy URL from Firefox Focus Android
  • 1 odgovor
  • 3 ima ovaj problem
  • 5 views
  • Posljednji odgovor poslao Mkll
I love Firefox Focus for Android. It is fast and the built-in privacy protection is great.
Maybe I am crazy or dumb, but I don't know how to copy a URL from Firefox Focus. When I tap on the URL in normal Firefox for Android, I can edit the URL. Long press brings up the option to copy cut select all paste etc.
In Firefox Focus comma I am given none of those options, nor can I edit the URL. The only way to get the text of the URL is to "share" the URL. Is the situation I am describing user error, a bug, performing as designed?
Thanks.
I love Firefox Focus for Android. It is fast and the built-in privacy protection is great. Maybe I am crazy or dumb, but I don't know how to copy a URL from Firefox Focus. When I tap on the URL in normal Firefox for Android, I can edit the URL. Long press brings up the option to copy cut select all paste etc. In Firefox Focus comma I am given none of those options, nor can I edit the URL. The only way to get the text of the URL is to "share" the URL. Is the situation I am describing user error, a bug, performing as designed? Thanks.
Hello this seems to be the intended behavior. However you can tap the three dots, select open with, choose Firefox and then copy the url from there.
